Got a scootrs disk brake for my lambretta and can't remember how it goes back together.
Problem I have is with the spindle when refitted.
When it is back together the end that is up against the metal bracket that holds the caliper will not let the nut sit flush with the plate.
The spindle has a ridged section that is ment to sit into the caliper bracket but it is slightly raised and the nut will not go to the bottom and meet the bracket.
Anyone got a diagram on how the parts slide onto the spindle in the right order.
