Sundance grips
Norfolk Boy
Main scooter: 2001 Vespa PX200
I've just put some sundance grips on my new PX headset, problem is there seems to be a gap between the grips and headset. What do you guys put between the grips and headset as I think this looks a bit untidy and will probably let in water. Any help would be greatly appreciated. Cheers Graham. :D
dave-g
Main scooter: Vespa P2
I cut off the larger diameter section of the original grips with a hacksaw blade (so you end up with a sort of large 5mm thick washer) then slipped that on before the sundance grips..
Norfolk Boy
Nice one will give that a go cheers
Toot-oasc
Norfolk Boy wrote:Nice one will give that a go cheers
You might want to also wrap some masking tape to the inner throttle tube so that the grub screws in the Sundance grips get a firm hold and don't begin to slide in use.
Norfolk Boy
Will give that a go also. Cheers
