Lights connection testing
jonboy
Main scooter: Vespa T 5 Classic
Evening all
I want to find a lighting fault on my lambretta
I've read that you can connect a batter charger to the regulator rathing tan having the engine running
It's 12 v ac
I have a Ducati 3 pin regulator
When I remove the yellow wire it's a spade connector.
From this point I need advice
10 inch Terror
Xbox live gamer tag: No.
Connect the positive from the charger to that and then the negative to earth on the bike.
Chris in Margate
Connect negative black of battery charger to a good earth. Connect positive red through a 10 amp fuse to the wire that you removed from the main loom to the output of the regulator. There is your feed to the lighting circuit.
jonboy
Thank you
    Users browsing this forum: No registered users and 24 guests
