Vespa Speedo refurbishment
storkfoot
Can anyone give a personal recommendation on someone who is good at refurbishing Vespa speedos please?
I have successfully done my own Lambretta ones in the past and it's true that they appear very similar. It's getting the bevel off that puts me off having a go myself.
It's an original Rally 200 speedo. Speedo has not worked since I owned it but odometer did. The cogs on that now seem to be fusing together and turning at once.
cgt75b
Main scooter: lambretta
Hi
I'm lead to believe there was a place in London that did it, but sadly long gone now.
The other one is speedoking.com.
Only trouble is its in the states, I believe he is very good though!
Good luck with it
Best regards Paddy
storkfoot
Paddy, yes, I know about the bloke in the States. I'd have a go of butchering, sorry refurbishing, it myself before I sent it that far. "Google" indicates that Retrospective in London may do it so I have just sent them an email ( scooter dealer to reply to email Shock ;-) )
cgt75b
If you need any bits give me a shout I may be able to help you out :D
storkfoot
Thanks very much.
Paul
storkfoot
Retrospective don't. They have recommended the lad in the States, Speedo King.
Surely there is someone in the UK?
gaz_powell
Jem Booth works wonders with lambretta ones - cant be much difference, worth a try ?
cartmel808
Maskes Vespa offer the service on their web shop... http://www.maskesvespaparts.com/Webwink ... meter.html ... they're based in Holland (I know your looking for 'UK') but still a lot closer than California... and cheaper aswel!
Never used them myself - but maybe worth a try...;)
storkfoot
Excellent. I'll follow both of those leads up. Thanks, lads.
steve c
my friend john can get the vespa needles off but I have never managed it with out damage, I even tried a cheap chinese instrument needle puller which just broke up, they are very stiff,you might have to heat it it with a soldering iron and then pull lever it,
I will ask him, you tube needle /clock hand removal and vespa speedos some one will have it, Steve Burdette is good but the post to usa makes it costly
