SIP speedo....latest version..
Timbo
Are they ok and problem free, any differences from the first batch? My 4 or 5 year old ones speedo has stopped working so will get a new one...
Shipleystevep
I got one earlier this year, all fine with it.
My only problem is i use the sensor and magnet for the speedo, sensor fixed to forks and magnet on wheel but they get out of alignment when i brake or on rough roads and the speedo fluctuates and mileage is innacurate. Ineed to fashion a mounting bracket on the fork link somehow so the sensor moves with the wheel. That said the unit itself is fine.
Timbo
Can you still use a cable?
lambro
Tim,
I have the SIP 2.0 in my rusty scoot, it runs a cable and has been no trouble for a year now.
I also run it with the low level warning fuel tap, I like that as well.
I have also fitted 2 speedo's for mates as well, but haven't tried with a wire fed speedo.
Shipleystevep
Yes you can still use a cable but, if your drive is a typical s**t lambretta drive (mine is) then the result is the same as a trad speedo. The pick up system is really accurate but you (we) need a mounting solution to the problem i outlined above.
Timbo
Cheers guys..
wack 63
Main scooter: '71 GP TS1
Not a clear pic but this type of bracket with a tube welded to it and a grub screw to hold the sensor. Image This one is the old MB speedo with the magnet glued to the hub.
Fux
Main scooter: li150 S2
I have my sensor bolted on the disk caliper and a magnet on the disk, works great (if you have an outboard disk that is).
No probs with the speedo, although is cuts out under about 1200 rpm running without a battery.
Nerdy Norm
Main scooter: Lambretta LI 150 S3
I've got a mark 1 Lambretta version as well as mark 2 Lambretta and Vespa speedos.
All work fine via the active sensor pickup (no magnet needed btw).
However, all three speedos forget the time after a few days without use. All scooters have batteries (although there is no permanent live connection on the speedo in any case). It's not a big deal, just means that if you want to know the time, you have to go through the setup procedure each time. But it seems to be a strange thing for them not to have addressed on the mark 2 version. And it's only the clock that needs resetting each time, all the other settings remain stored.
Lambretta LI125 Series 2, Lambretta LI150 Series 3, Lambretta J100 Cento, LML Star 150 2T
    Users browsing this forum: No registered users and 32 guests
