Split die thread chaser
mickymidas
Main scooter: Vespa Rally /P200
have just ordered that very same kit from Tool Academy £18.50 inc postage :)
2Ronnies sc.......Chuckleism is the way forward
sunrisemac
Main scooter: Lambretta GP150
try googling 'metric die nut'
Muppet
C’est la vie
dirtyhandslopez
Not going to be easy spinning the die for the 5mm with a 1" socket, that is a small thread to be wobbling a big socket around on. Best make sure the sockets fit tight or the threads won't chase properly either. Good idea though.
Now, if you had two halves you could screw together, that would be the ticket, you could slowly start on a bad thread then cut deeper as the thread cleaned up.
Right then, off to the patent office...
That's not going anywhere...
