Changing gear selector spring
LeightonRB20
- registered user
- Main scooter: Alwyn Pushpak RB20
- Contact:
My GP is jumping out of gear when under pressure, that is, when accelerating. I'm told that it is probably the gear selector spring. I'm sort of OK with a set of spanners, so is this something that I could tackle myself, or would it be beyond the realms of someone with a 'reasonable' amount of skills, or is it far too complicated? What do you think?
- drunkmunkey6969
- Moderator
- Contact:
Only one way to find out bud.....get stuck in!
Chris in Margate
- registered user
- Main scooter: Lambretta 1964 225 Special
- Contact:
Before attempting the strip down just convince yourself that the cables are adjusted correctly and that the external selector arm is not catching on anything and is free to travel from 1st to 4th without obstruction.
That said it's not a 5 minute job and you'll need some tools like clutch compressor, clutch holder etc. Read Sticky's book on this section and then DO IT. It's initially a little daunting but not that difficult.
10 inch Terror
- registered user
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
- Contact:
As said, it's an easy job, but probably one of the most time consuming, and will require almost all of the Lambretta workshop tools. The clutch, gearbox, rear hub and lay shaft need to be removed ( it can be done with the lay shaft in situ, but is very akward ). If, you have all the tools required, then it is an easy job.
I would suggest it's not a task for the novice Lambretta mechanic. If you have a mate who has experience? Get him involved and learn as you go.
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
Also if you've got rubber gators on the gear cables,these can compress when you select a gear and sometimes push the gear swivel causing it to turn and drop out of gear.
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
bearing in mind it might not be the spring !! it could be a worn gear or selector or other........
Might be worth phoning round and seeing what the cost for a strip down and re-build is and off setting that against the time, inconvenience, cost of new tools, potential balls up, etc.
LeightonRB20
- registered user
- Contact:
Thanks for the input, chaps. I'm pretty confident that it's not the cables, based on the fact that when I slackened them off, the problem became worse. My theory being that the tighter cables helped to keep the selector in position?? I think I'll have another look to be absolutely sure, then get some prices.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
