Aldi Torque wrench
EddieStone
Aldi are selling 1/2" torque wrenches for £15.99 from today (22/10/2015). At last my hub nut will be tightened to the correct toque!
Monty
Dont wait for it to click on the flywheel it wont
EddieStone
Because it's left hand?
Monty
Yes it may well have a ratchet to go left or right but the torque setting only work one way. The type that the square drive pushes through can be used both ways. A few others also bar or digital. Been a few sheared or mullered the nuts waiting for the click.
EddieStone
You're right, it doesn't click left handed. Just tried it on a wheel nut at a low torque. Many thanks for the tip.
alanscottj
What's the minimum setting on these? I'm looking for one for the smaller torque nuts on a scoot.....
EddieStone
28Nm is the lowest setting. It's not for small torques - it's about 15" long.
alanscottj
EddieStone wrote:28Nm is the lowest setting. It's not for small torques - it's about 15" long.
Cheers bud :)
CPH Lambretta
Main scooter: DL 150 1970
I broke a flywheel, it sheared down the keyway, when my ebay torque wrench that was "reversable" turned out not to be :(
Slow is the new fast!
