Den
hand held rev counter
Den 08
- registered user
- Main scooter: lambretta Gp 225
- Contact:
As above has anyone used or use an hand held rev counter like this one eBay no 251355349676 can be a pain sometimes trying to strobe and look at rev counter at the same time
thoughts gentlemen please.
Den
Den
- drunkmunkey6969
- Moderator
- Contact:
That item won't do the job, that item strobes rotating parts, not electrical/ignition pulses.Den 08 wrote:As above has anyone used or use an hand held rev counter like this one eBay no 251355349676 can be a pain sometimes trying to strobe and look at rev counter at the same timethoughts gentlemen please.
Den
I use a Koso digital rpm counter on occasion whilst dynoing, it has wire which attaches to the HT lead to give readings. However it is so sensitive that you only need to hold it near to get a reading.
When strobing, I use a strobe gun with built in RPM counter so I can strobe timing marks and check RPM for variable ignitions/MTech etc.
Den 08
- registered user
- Contact:
Typical just being me tightwad self I have seen the strobes with the built in rpm just trying to do it on the cheapdrunkmunkey6969 wrote:That item won't do the job, that item strobes rotating parts, not electrical/ignition pulses.Den 08 wrote:As above has anyone used or use an hand held rev counter like this one eBay no 251355349676 can be a pain sometimes trying to strobe and look at rev counter at the same timethoughts gentlemen please.
Den
- registered user
- Main scooter: Lambretta
- Contact:
I have one of those and can verify it works OK.
Odd thing is once you set it it never seems to switch off again.
