fitting side panels
dave411
Main scooter: Li 125
I have tried fitting my side panels back on with new rubber channeling,but they wont fit,no where near.If I push them on,it still wont go anywhere near the spring retainer,and then they are stuck tight,have to really battle to pull them off.They are the original side panels,and the same frame.Its an Li 125,1963.
Is there a magic fix?
bristolmod
Dave- just make sure the new rubbers are on the correct way round.
To be honest, I tend to slip the panel on at the front, then push down until the handle is in the approximate correct position- I then turn the handle with one hand and use my other hand to "walk" the inner mechanism over the spring mechanism- it can be a real effort at times.
Its much better to be tight than risk having the panel spring loose and fall off.
Chris
Scootering since 1968.
Try lubing the rubbers with Mr Sheen or similar silicon spray as it helps to fit and remove the panel. The best ones are the plastic type, the rubber ones grip too much and won't allow the panel to slide into position.
dave411
Thanks guys.I cant get the handle anywhere near the spring,maybe a bit of lube will help.Where can you get the plastic ones from.
Chris,the Embelishers look great.Havent fitted them yet,but the blue is a near perfect match,cheers buddy :)
Chris in Margate
There are cheap rubbers that really make fitting a pain. Whatever rubber you have though you still have to encourage the top front edge on whilst manoeuvring the handle into place.
Have you had your panels blasted by any chance? might have get a little distorted in the process. Do they go on ok without the rubbers fitted?
dave411
Yes,they fit perfectly without the rubbers.
They were chemicaly dipped.
Best rubbers I've found. http://www.scooterrestorations.com/lamb ... air-black/ Also do grey.
