P200E No Spark
ColB
Main scooter: Vespa P200E
Is there a rewire kit I can buy for the stator plate, one that will include all the possible parts needed for a refurb?
ColB
Resolved. I changed the flywheel back to the original one as I had a lightended flywheel on. It sparked and then all started up. It was defo a schoolboy error on my part as this must have had something to do with not sitting on keyway correctly... Thanks for all the advice...
gaz_powell
Was it a one with two keyways ? (for V range and PX )
ColB
Yes gaz_powell.. If you look at the flywheel then one keyway is at the 10pm position the other is at 2pm position. Px is the 2pm position I believe..
mick1
Main scooter: Li Avanti 225
should still have sparked though.......even on wrong keyway
