Stator/CDI issue
molibdimum
Posting for a mate.
Can a stator that's starting to breakdown take out a perfectly good CDI?
Hes been having problems with poor starting and occasional cutting out so changed the CDI and all was well.......for a while but the problem seems to have come back.
Plug has been changed also.
Knowledge
Have you tried the obvious, and tried running with the green wire from the kill switch disconnected from your CDI? This would at least eliminate this from the equation, as the symptoms you describe could be a faulty kill switch or key switch.
Martin
Get him to check the connections to the CDI very carefully too. Could be a badly crimped or corroded connector?
molibdimum
Will do guys.
Keep the suggestions coming and Ill let you know how he gets on.
holty
Main scooter: lambretta gp
check the earth tags on the stator plate they are peined over and can work loose, i solder them to the backplate for a perfect connection.
holty
graham li
Main scooter: lambretta li 150
fault started when i whent to start scooter to ride home this scooter allways stars 1st kick so tried many times then changed the plug and it started ok so rode home and it was fine i let the scooter tick over for about 5 mins and it stopped like i had turn the key off so i tried to start it and no joy so i checked the spark and i thought it was maybe a little weak and tried again no joy then looked at the fuel flow all good then took the carb off cleaned it out with air no joy so i changed the cdi and off we go the next day whent all the way to cadwell 90 miles each way all good got home let it tick over and back to same problem so do i change the stator and is the new cdi had it thanks GEE
Have you tried Knowledges suggestion re the green wire to the switch?
Had that earler with a friends scooter new plug started ran fine turn key off then back on wouldn't start or if did for a few mins swapped everything twice on his request , swapped his stator for mine problem disappeared , had new LT coil and pick up fitted (cheers jarv) refitted problem cured , NEARLY NEW BGM stator
graham li
will try green wire 1st and if no joy go on to new stator thanks for your help gee
Micky Tapp
Main scooter: Lambretta GP200
Have you sorted it dude?
