TSR Evo pipe
wack 63 wrote:Just to add from my original post, after a carb tweek the scoot now goes really well but it broke the stinger to cone joint after 100 mls. The strengthener did its job and he didn't lose the endcan. TSR replaced it straight away and now supply a casing bracket so fair play to them.
Thats good to know did you post on facebook about the stinger breaking ?
Was it mild steel or the stainless version
wack 63
Main scooter: '71 GP TS1
No to FB, and it was the mild version that broke. The strengthener would be better under the stinger instead of the side
I like the EVO pipe, very good as a road/touring pipe, here is a graph of the EVO vs a more revvy/power pipe setup: viewtopic.php?f=53&t=35327
Info here about tail can support: viewtopic.php?f=12&t=35326
Fux
Main scooter: li150 S2
I have a Pipe designs bullet lying around. Is it almost the same pipe?
My stinger snapped and I welded it up with a support bracket and its been on the shelf since.
I`m tempted to put it back on but not sure is it is an improvement on my MB clubman...
Fux wrote:I have a Pipe designs bullet lying around. Is it almost the same pipe?
No, not the same....chalk and cheese.
Bullet is more power/revs.
EVO is road/touring.
Fux
Then its the charger I have. Its def a touring pipe.
slangen
Main scooter: TV200
Lambretta Sash wrote:same issues with grounding out with cast stub fitted, like most things they need a fettle to suit
Sir, did you shorten the stub? Or how did you solve it?
    Users browsing this forum: No registered users and 21 guests
