blown piston on TS1
dazz-uk
On a ride out today, I managed to blow my a hole in my piston, no nip up just doing 60 then a phew noise and no power, due to weak mixture I think, upon strip down the barrels looks perfect, so will be be ok to get a new piston and rings and rebuild, or does it mean new barrel aswell?
bristolmod
ask yourself where the molten alloy has gone...........check your big end very carefully.
Scootering since 1968.
Adam_Winstone
... and identify and correct whatever the fault was that holed your piston!
bristolmod wrote:ask yourself where the molten alloy has gone...........check your big end very carefully.
This is true, stick your little finger in the transfer ports and you'll find it coated with fine ally particles, the stuff gets everywhere :( You might be lucky blasting out the crank case with carb or brake cleaner but there is a very real risk that particle will find their way into the crank seals :(
dazz-uk
Most of the ally particles were in the transfer ports and on the reeds, gave the crank case a good blast with brake cleaner seems clean, but I'll strip back crank this week.
    Users browsing this forum: No registered users and 68 guests
