Italjet Dragster leaking water
ferritt
My new to me dragster is leaking coolant from arount the plastic skull cap. I've replaced the rubber skull cap gasket with a new genuine item but its still leaking from the same place. Just wondering if it could be the plastic skull cap itself that is warped and not clamping the gasket correctly. Has anyone else had experience of a skull cap being warped or have any other ideas? Thanks.
TED CRUD
I would replace the plastic scull cap with a metal one and if you want go overboard and use a sealant
Smash Ya Pastie
Washington Posse s.c
ferritt
Thanks for the reply, are the metal ones available new and from where, or is it a case of buying used?
