ts1 carb settings
roadrunnerian
Hi i'm running a ts1 with a franspeed supertourer 35tmx with a breathe sweet filter I have a main jet 310 with a 58 needle and 2nd notch down is that about right thanks
col68
Main scooter: lambretta s2 li225 ts1
I am using a 57 needle same clip and a 315 main with a ramair filter and 22.5 idle and a supertourer set up by diablo on dyno. col
roadrunnerian
Hi m8 thanks for the reply where did you get your 315 main jet from thanks :D
mikeallen
Xbox live gamer tag: junkyevenflow69
I'm running standard TS1 225 on 35TMX & supertourer with Ramair filter with hole in panel.
300 Main
57 needle on 2nd clip down from top,
22.5 pilot
Air screw = 1 1/4 turns out
roadrunnerian
thanks Mike
col68
roadrunnerian wrote:Hi m8 thanks for the reply where did you get your 315 main jet from thanks :D
Got a set from mb development . col
    Users browsing this forum: Semrush [Bot] and 10 guests
