Long stroke 150?
scooterslag
Just a random thought while I was at work (my jobs pretty boring :) ) I've often wondered why innocenti didn't carry on making engines with a longer stroke crank after the TV175, its a great engine, lovely power delivery, silky smooth etc Recently I've come across a couple of TV175 cranks for half decent coin on ebay and thought how about making a long stoke 150 using the TV crank, packer and GP150 top end (Italian though the Indian GP barrel has a crap port layout and less power) What would be required? would the piston need to be shortened? compression ration changed? like I said before its just a random thought though I do like the idea of a smoother 150 engine. Paul :)
The mack daddy on the left!
eden
TV 175 have longer rods not longer strokes.
And a different gudgeon pin position on the piston to compensate.
You'd need to find a piston to suit or use a 9mm packer.
scooterslag
cheers for the replies, like I said just a random thought, so it is possible but would require a lot of arsing around?
Adam_Winstone
TV SI had a 60mm stroke
But would the crank fit in anything else?
dave wheeler
bore to 64mm and use a suzuki 185 piston and a 2mm packer,your right though, a 116mm rodded engine is way smoother than the 107, wish there were more kits with options to use this rod, a GT kit in this format would be awesome
eden
dave wheeler wrote: a GT kit in this format would be awesome
That's the rod I use in my GT250 tune. I like it :)
but a 115.
Adam_Winstone
This is why the Mugello range is available with Pistons for both the 107 and 116 rods, with the 116 option being more popular in Italy than in the UK.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 35 guests
