Plug chop and plug colour help please - happy ending
Did Dan get you to adjust your timing in either direction?
Shipleystevep
No. You did Adam, i had moved it to 17 degrees based on your wise counsel earlier. Thank you. Dans tuning advice confirmed your views,
li150ss2011
Main scooter: li150silver special
have you done plug chops since new adjustments? what do they look like now?
Architecten
Main scooter: Allwyn Pushpak GP125 (RT200)
Chris in Margate wrote:Cheapest way is Coaster's mountain bike inner tube. Cut in half opposite valve. One end over downpipe and the other end over inlet manifold. Secure with jubilee clips. Pressurise with pump and wash potential leak areas with soapy water and look for leaks.
Out of interest does the piston have to be in any particular position when testing??
