ts1 best gearbox ?
woody
Whats the best gearbox to use on a ts1 225 ? was thinking of sx200 but what should the front sprocket and crown wheel be ? cheers
Depends on lots of factors , tune , carb , pipe weight my choice is indian GP WITH 19T front spocket and 47T rear I like the longer 3rd and the pic up in 4th
speedy
As above and I'm 17 stone,cheers,Speedy.
Adam_Winstone
Even with a standard TS1 the choice of exhaust makes a massive difference to what gearing you'll require. If you look on AF's site, AF's fitting instructions, Sticky's manual, or a number of other places, they suggest top gear ratios for various pipes.
kevspeed
Im looking at the Indian 200 box using 19x47 myself,but i have heard that my choice of pipe will affect it,im not a fan of big end cans sticking out the side of series 1 and 2 machines,so i opted for the JL 'Curly',hopefully this set up will work for me,as i dont plan to get the TS tuned!
Hope it "rockets" to 92mph .....
kevspeed
If i can get it to rev over 7k pulling my TV200 box with a 17 tooth it might!!
woody
right i,m using old skool gear for this , 34mm amal powerjet and msc micron, barrel is standard but head is a reworked ralph saxelby one , now what everbodys best suggestion please
holty
Main scooter: lambretta gp
close ratio gearbox is best, ive bought them off rayspeed in the past, dont think they make them anymore,last one i got was from joe at drax, they give you a high first gear but once your away the close ratios help to accellerate nicely without dropping out of your powerband, top speed will depend on which front and rear spocket you use, that sprocket ratio is linked to the torque that the engine produces,exhuast and other modifications come into play as well.
holty
joespeed
still have a few close ratio boxes for sale!
    Users browsing this forum: Google [Bot] and 13 guests
