Spanish/Italian panels difference?
karmsemaj
Main scooter: Lambretta LI 125 special
I'm currently on the look out for some original LI special side panels. I've found some Spanish panels but before I spend the money can anyone tell me if they are the same as the Italian ones and will fit? Don't want to waste my money if they are different, cheers.
bristolmod
the Spanish Special panels are wider to accommodate the slightly different fuel tank.
In practice you won't notice it.
Chris
Scootering since 1968.
karmsemaj
Cheers Chris
steve c
chris i thought that the spanish and italian were very similar but
the later spanish ones are noticeabley wider with about 10mm extra on the top flat chamfered area, must have been welded in must only be 1978 or so scooters,
regards
steve
bristolmod
As regards size you'd need to ask my missus!! :D
I'm not sure re the later Spanish ones- there is a slight difference on the earlier stuff
steve c
I totally agree with you, I almost brought a set of the later ones but there is quite a difference
    Users browsing this forum: Ahrefs [Bot] and 11 guests
