So, it's a 58 stroke and 107 conrod in there and a deck height of -0.3mm assuming you measure the edge of the crown to deck as opposed to the highest point of the piston crown?
So exhaust port wise im getting 36mm from top of the exhaust port to the top of cylinder giving me 166.73 degrees of exhaust duration
Transfer duration works as 47.45mm top of transfer to top of cylinder giving 113.14 degrees
Inlet duration? Piston skirt length (edge of crown to bottom of piston skirt on inlet side) is 63.06mm however there's a cutout where i have measured it and there's about 3mm either side of this still which is technically the bottom of the piston so hope i measured the correct part? Inlet Floor Depth (Top of Cylinder to Bottom of Inlet Port) is 98mm
anyway if correct the inlet duration is working out at 174.04mm
Does anyone know if ive done it right or cocked it up?
