This is the standard 24/24 carb with a 130 main jet being the only difference to the stock carb, ie with a BE3 mixer. Before I had the Malossi tuned, it ran well with a great plug colour. Since then the barrel ports have been tweaked, I have changed exhaust from a Sito plus to the BGM big Box and set up Ky-Tronik ignition.
In this form, it runs great with plenty of pull and feels right and the tickover sounds and feels right.
But just done plug chop at 1/2 throttle and its probably just a bit too lean. So to richen up this low end, do I change the mixer tube to a BE4, or should I be looking at something else in the jetting zone.
Plug chops on a Rally Malossi 210
- paulnobodyimportant
- registered user
- Main scooter: varies
- Contact:
- wack 63
- registered user
- Main scooter: '71 GP TS1
- Contact:
Something to peruse http://www.scootercentral.net/forums/vi ... xer#p87017
Norrie Bodge
- registered user
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
- Contact:
reading here should help -> http://scooterotica.org/forum/viewtopic.php?f=8&t=27378
& a look at this pic
http://i265.photobucket.com/albums/ii22 ... ontube.jpg
