jetting pointer...
Lam-d
Main scooter: 71 Gp200e
ok need a bit of info for a pal of mine his plug is a tad grey (w27 or b9)but the carb is jetted as per recommendations from "tuner" what would you suggest we check or change ... It a 25 mm (through airbox )on an RT225 with Ancillotti pipe jetting is 98 main 46 idle needle is dp29 2nd clip and atomiser is AQ270 any suggestions are greatful ..
dave wheeler
the best way is to go up about 115-120 on the main so it 4 stokes badly, then work down until it runs clean and id stick with that, your atomiser seems rather large as well, my set up on a tv175, standard apart from 24mm phbl and sito clubman through a baffleless airbox but with filter is 100 main, aq 264, d22 3rd notch needle, 48 pilot and 60 choke, the last 2 are too big but i can work round them and like it running cool on over run
