ideal carb size for a stage4 GP and RS pipe
Davidsquaredson
Main scooter: Early Eibar Jet 200
Hey,
a friend has a stock GP engine and carb, but added a scootrs expansion chamber exhaust. He wants more performance primarily for in town use and period light touring (max 100 kmph) . So low to mid range torque. I think a clubman would be a better pipe but he's already bought the scootrs exhaust.
I've got a stage 4 tuned jet200 barrel I'm not using so was going to offer to him. What size Dellorto carb would ideally pair with this. Assume using a bellows and remote foam filter.
tx in advance
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Norrie Bodge
26mm delly would be ideal IMO
Davidsquaredson
thanks!
I have a 28mm in my set up and I thought it was too much carb for this . Was thinking it would be 24 or 26, was waiting to see what someone with experience would say.
Cheers
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Why not a 22mm im hitting 100kpm with my stg4 and clubman it pretty much flat lines after that though as I was expecting a genuine 70 mph :(
shaunmc
Main scooter: Lambretta GP200
I'm using a 26mm delly on Stage 4 with a scorpion exhaust no filter changed from 30mm. Really happy how it performs.
Davidsquaredson wrote:primarily for in town use and period light touring (max 100 kmph) . So low to mid range torque. I think a clubman would be a better pipe but he's already bought the scootrs exhaust.
I think you're right too.
Strummer10
Must admit my GP 200 stage 4 with a 22mm standard carb and scoots rs expansion flies and is as quick off the mark as mate's TS1 and gives it a run for it's money.......but I have decided to put a 30mm delorto on it with breathe easy and see how it goes after
vespanic
You might find his Indian barrel is stage 4 tuned. Most of the barrels in the last few years have been stage 4 tuned as a standard.
gaz_powell
The standard Indian SIL barrels are very loosely stage 4 - they are not like a hand attended to stage 4 where ports are cleaned/polished/edges along with manifold matching.
There is a bit of a difference.
Back to the original plot I like the 26mm not long changed a 30 for one for a mate and it's much better. On a factory 200 SIL barrel with a bit of tidying up and manifold matching..
