play in rear wheel 1970 gp150
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
"some" play is acceptable and indeed probably required to allow for expansion when warm.
If you rock the rear wheel backwards and forwards top to bottom or side to side, you should just detect a very small amount of play- if its a lot of play then its either the bearing worn; the cone/hub worn; the rear hub nut not torqued up enough or the gearbox end plate loose.
There is mention, I think, in the original 1960's WSM regarding this
Scootering since 1968.
