6305 Driveside Bearing
Boreham
Main scooter: GP225
If you are using the bearing with fitted oil seal (SKF / MB) do you still use the halite gasket between the plate ?
Boreham wrote:If you are using the bearing with fitted oil seal (SKF / MB) do you still use the halite gasket between the plate ?
Yes
