two colour spark plug?? anyone have that before?
Davidsquaredson
Main scooter: Early Eibar Jet 200
Hi,
dialing in my carb. Scooter is running very well, if anything, I can tell its slightly rich in the needle, I could probably move it one clip position. I took at a look at the plug. The colour is almost split down the middle, milky tea on one side, black on the other.
I've never had that before on a scooter. Any ideas?
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Morgan
Main scooter: T5 Vespa Mk1
blown head gasket ?
Donnie
Is it an ally barrel ? ie mugello/ imola etc?
Donnie.
Davidsquaredson
800 km on a new gt200 iron cylinder and porcupine head. Head gasket is metal 0.5mm. I will go have a look for signs of fuel being blown out.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Davidsquaredson wrote:800 km on a new gt200 iron cylinder and porcupine head. Head gasket is metal 0.5mm. I will go have a look for signs of fuel being blown out.
Doesn't the GT head have a blank plug in the centre position? is it tight?
watto66
I had a similar problem on a GT 186 kit with the centre plug not being tightened ( I assumed it was tight when I bought it ! )
Check that and as stated the gasket you have to loctite that central plug in .
Cheers
Davidsquaredson
watto66 wrote:I had a similar problem on a GT 186 kit with the centre plug not being tightened ( I assumed it was tight when I bought it ! )
Cheers
Correct in 1. Just took cowl off. I could almost unscrew the plug with my fingers. Will tocktite it in. What torque did you use? Because there is no gasket, 20 Nm? Also, I had a ring type heat sensor pick up around the base. Is this a problem, does it make it easier to not get a good seal?
THanks
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
