rear hub removal problem
HxPaul
Morgan wrote:I've seen Ben at AF put the engine stand on and give the rear wheel a couple of bangs with his hand and Bingo the wheel/hub came loose, tried it myself and got a sore hand and hub still there !!
I always use this method,but instead of hitting it with my hand I kick the wheel and then turn it,kick it again and so on,until it comes off.They say you can buckle the wheel rim using this method,but after doing it for years I've yet to have a problem.
