Chains
Jonn
Anyone else found the listings for chain pitch and sprockets in manuals wrong? I have 15/48 sprockets and the info is 81 pitch chain.This doesnt fit too short by quite a bit.An 82 pitch chain is way too long.Who'd have thought 1 link would make such a difference? Anyone have similar trouble? This isnt the first time its happened.
Grumpy225
15/46 =80
15/47 = stretched 80
15/48 should be an 81
What make of chain? Could be you have one that is slightly out of spec? I've found these numbers have always worked out for my builds.
Jonn
Got iwis chain the 81 is too short rear sprocket is about 4mm off centre no way getting clutch spider in
Where did you get it from?
There are, I believe, two types of Iwis chain and there are also fakes out there.
bristolmod
my monies on the sprocket(s). If they are poorly manufactured they will throw out the spacings by a big amount.
Scootering since 1968.
Jonn
Got the chain from camlam ,and the rear sprocket is a camlam 6 plate,SIL front sprocket.
Chris in Margate
You need to measure the distance between the looped ends and get somebody else to measure a known good one.
The silver iwis is what you need the black type are industrial chains thesilver automotive
Jonn
They're the silver chains.
81 and 82 link chains for comparison,not a lot in it.
81 link chain too short
82 link chain seems a lot of difference for 1 link extra
Daggs
Personally, I would think that non-standard rear sprocket is the issue.
    Users browsing this forum: Google [Bot] and 12 guests
