what exhaust
idc23
Main scooter: lambrettatv175 3
I am going to change my jl3 it is very low, i am running a mugello 186 latest, 28mm delly phbh, electronic bgm .Just wondered what others are using, i dont want to waste money on a fancy looking thing , i want something that works & not too loud.
Cheers Ian :)
cgt75b
42mm clubman would be fine on that.
speedy
Is it the low slung down pipe from the stub manifold that makes you say it's low? If you still want an expansion pipe and not a box pipe like a clubman, then you could consider the Fresco. AF do them in 48mm and 42mm, with oval and standard flanges. Very good pipe for mid range power and a reasonable price, with very good ground clearance.,cheers,Speedy.
Timbo
MBBGM big bore Clubman for the standard look if you can find one...... :o
idc23
Yes very low slung from the stub, bloody dangerous 2 up :shock:
