flywheel
jbg584
Main scooter: Lambretta 1960 series 2
Hi
pins on my flywheel on series2 have come forward and jammed motor have got flywheel, of can the pins be replaced if they can be removed or does it mean another flywheel
Ray
Not clear what you mean by pins?
If you mean the rivets holding the flywheel to the boss, then they can be drilled out and replaced with high tensile bolts.
jbg584
Hi 4 pins that secure flywheel fan to flywheel
bazza3004
What k8nd of flywheel is it eg elec or points Li or GP taper . I may have a spare you can have.
jbg584
Hi bazza3004
Its a 1960 series 2 standard 4pole been on scoot since I bought it in 1960 appreciate if you can help
bazza3004
Hi jbg584 ive sent you a pm.
