LD ish
GLscoot
Main scooter: Vespa GS150
http://www.ebay.co.uk/itm/281763054764? ... EBIDX%3AIT
what about this for your oil, a little expensive but I think they look good, have you thought about using acf50 just to give the body work a little more protection. nice work & excellent looking scooter.
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
thanks , but that tin is far too new looking for this scoot, no ac50, this one was genuinely pulled out of a hedge , ill just leave it aged as is :D
gerryjunior
i welded a simple bracket bent around the shape of the dampers to the fork leg ,for the anti dive, it works a treat,,
gerryjunior
ive also fitted some led indicators for safety,
jason frost
gerryjunior wrote:i welded a simple bracket bent around the shape of the dampers to the fork leg ,for the anti dive, it works a treat,,
Have you removed the peg from the link ?
gerryjunior
haven't removed anything from the link.
gerryjunior
im building a new engine for this , a casa ss225 ,kit no 29 , lth clutch ,li 150 gearbox, 58 mil crank, carb and exhaust to be decided..
wrecklessrobbie
Main scooter: li150
Gerry
Are you running a battery on this scooter?
How have you wired the indicators.
I am looking to fit indicators on my series 2. I am not planning on using a battery, I was hoping to use a relay on ac...similar to the early p200 set up.
Do you have a wiring diagram. I will be using a AF electronic wiring loom but will add more wires.
Thank you
Robbie
gerryjunior
yes im running them through a battery .
jason frost
gerryjunior wrote:haven't removed anything from the link.
So I take it that the caliper plate is not connected to the link ?
