MBgm RT225 Jetting
Lam-d
Main scooter: 71 Gp200e
Lads a pal of mine will be running an RT225 std GP 200 gearing on a 25mm delly with either a Sito Ancillotti Or Bgm pipe and was wondering what jetting people are using as he has asked several dealers\tuners and got several different answers ...any help grateful
There'll be no 'right' answer - just what's right for his engine. Best anyone could give you would be a ballpark which will be enough to get it going but you should check it by plugchops or a dyno test
Lam-d
Ball park would be fine bud ....i gave him this .....running through an airbox
MB.25MM delly KIT...60 CHOKE ,,53 IDLE ..40 SLIDE ..AQ264 ATOMISER D26 NEEDLE 2ND CLIP DOWN ,,MAIN JET 100..VALVE 2.50
was told that the Atomiser was to small and to change the needle on the above but didnt say change to what ffs lol...
if anyone can add suggestions or additions to the above please feel free as the more the merrier and will post finding on here ...Also Dyno is not an option as there are none were he is or within 100 miles ...
