Lambertta Colour?
barnsleybilly
Main scooter: Li200
Bristolmods got the only surefire way of finding a clue - you need to look where blasting & resprays are unlikely to have touched it - inside the frame headstock and in the engine mount tube on the frame are a couple more places to investigate.
DaleUK
Main scooter: 1962 Li 125
So other than the above there's no real , sure way of knowing from frame and engine number?
Correct
DaleUK
Did a little bit more Digging as they Say... Found this Colour
Any ideas??
DaleUK
Might need to Zoom in on lock catch!
Daggs
The lock/catch would not have been painted by Innocenti.
I think you're probably right. I doubt Innocenti would have sprayed it in situ and plastered the rivets and all.
Grumpy225
bristolmod wrote: If its an li125 s3 it's probably duck egg blue
In the US it's been called Riverside blue, LI Blue, Baby blue etc etc.
At the end of the day I call it a manly blue
Reality is your LI was either blue or mint green, pick a color and run with it.
If you can find a little spot under the frame loop that wasn't painted over you MIGHT be able to ascertain what color it was from the factory. The blue and green look a lot alike after 53 years.
There are no color descriptors tied to frame numbers (unlike modern cars).
DaleUK
How many Colours were used in '62
