Lambretta leakdown engine testing kit
Darrell Taylor
Main scooter: LAMBRETTA
ive pulled this kit together comprising of 15 items in total to form a comprehensive leakdown testing and sealing kit for lambretta engines
2 exhaust plates for each cylinder type with 2 seals
4 different sized carb bungs for the smallest carbs 22/24/25 - 28/30 - 32/34 right up to 36/39mm carbs complete with 4 tyre valves fitted
1 footpump with pressure gauge
1 aluminium spray bottle
1 tube of loctite 5910
this came about as a few friends wanted a kit but didnt want to pay £160 for the motion pro kit i use so set about pulling a low cost kit together for them that i have decided to offer to all
leakdown testing is the most important part of good engine building as drawing in air is most certainly gonna blow the motor ,lambretta engines in particular suffer badly from air leaks in many areas so is a neccessity to check.
price is £59 so a 1/3 of the motion pro kit
Darrell Taylor
if you have a footpump or compressor with tyre inflator and spray bottle and sealant already
then the plates kit can be bought for £42 and postage cost will be reduced considerably as will fit in a small jiffy bag
You thought about offering kits with just the options folks require? I.E.
28/30 with std exhaust
32/34 with oval
Plus or minus the other bits?
Elite-225
Main scooter: GP 225
Brilliant .. ! Nice essential i think yes
Darrell Taylor
yes i thought of ,but didnt get round to typing it but had a few enquiries like that what ive sent out already.
workshop kit complete as pic £59
workshop kit minus bottle,pump and sealant £42
single user kit £22 eg ts1 and 30mm dellorto
Yanker
Nice idea
The 'Carb bungs' incorporate the air valve then?
Different approach to the 'usual?' exhaust + inlet bung and plug mounted pressure regulator/monitor.
Stampede
Main scooter: SX200
My kit arrived today, looks quality - thanks!
Donnie
Are these still available Darrel?
Donnie.
Darrell Taylor
yes still got plenty in ta.
Donnie
Just need a single user one for 30mm delly plus standard port ie gt186/mugello. How much would that be and would it go through a standard letterbox, i only ask as im about to go on hols for 10 days so wouldnt want the post office to be holding it and then lose it
Donnie.
    Users browsing this forum: No registered users and 58 guests
