Why would you Why wouldn't you
Train Driver
RT cylinder what are the advantages and disadvantages of fitting a reed valve.
Not a home job but one done by a professional.
Minority
Main scooter: Li230 S3
For
1. Better fuel consumption
2. More power (If port timing changed to take advantage of the reed valve).
3. Reduced spitback
4. More flexible engine.
Against
1. Cost
2. May be more difficult to fit a filter.
Train Driver
Are you watching timbo :lol:
Timbo
Minority wrote:
Against
1. Cost
3. One more thing to go wrong
Train Driver
Timbo wrote:
Minority wrote:
Against
1. Cost
Could you explain a bit more about your No 3
I think most modern two stroke engines are reed valved and the never give problems
psychedelicropcircle
4. Better response from the engine low down.
5. Don't have to rev the s**t out them in town.
Timbo
.....RR1....... :P
Timbo
.....I don't have to do that anyway with my set up...... ;)
dave411
Main scooter: Li 125
Two strokes need reed valves.End of
Adam_Winstone
If you want the advantages of a reed valve, why would you try to fit an aftermarket item, rather than change to a kit that was designed to incorporate one from the start? The biggest issue with a bolt-on reed manifold is the space that it takes up and the limited clearance to panelwork, whereas the reed designed kits tend to have it designed in to maximize clearance.
Does looking at this option suggest that you bought the wrong kit in the first place?
I'm raising questions, rather than giving my opinion as I too can see pros and cons for both.
Adam
