Ignition switch conversion for Li125 S2
Mike - - Bristol
Main scooter: Silver Special 195
How easy is it to convert the TV switch to fit an Li.
Rimini have some and I wondered if it was a straight forward change.
Cheers in advance.
HxPaul
I've fitted an ignition switch to my series 2 Li 125.I use the ignition switch for ignition,side light and headlight.I just use the handlebar light switch for dip,main beam and horn.
Mike - - Bristol
Thanks for the reply Paul.
Did you have to fettle the switch to get it to fit or was it a straight swap.
lambro
Mike - - Bristol wrote:Thanks for the reply Paul.
Series 2 is a straight fit, I fitted one to my bag o' rust S3 Spanish Special and I had to fettle the inside for clearance,
so much I don't have a steering lock.
Odd, as Italian Specials had them with no issues :?
Shaun.
Mike - - Bristol
Thanks
HxPaul
I had no problems fitting my switch,it went straight into the headset in place of the cutout button.
Mike - - Bristol
Just what I wanted to hear thanks.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 8 guests
