Not Running
Lamaddict
I can normally sums things out but not this time.
Broken down, sounded like a carb problem. Anyway, carb cleaned (20mm), new plug, changed coil, reset points, great spark still not running. A rasping hiss coming from the carb area? Also the plug isn't getting too wet?
Stuck ring would be my guess, what does the compression feel like? Had any nip ups lately?
Also worth checking for any air leaks around the carb but I would expect you to be able to start it even if you have to put your hand over the carb.
mick1
Main scooter: Li Avanti 225
The "hissing" would suggest an air leak. Even a small air leak in the carb' area would cause difficulty in starting (makes the choke useless).
Good call on the rings, looks like the top end needs to come off.
Lamaddict
Bottom ring had broken up, also noticed the circlip broken. Off to AF's this afternoon for another piston or kit. I wouldn't care but I'm on my holidays, bloody scooters.
Lamaddict
24 hours later back OTR. New piston from Rayspeed 35 quid and rebore while I waited 20 quid, top job!
Shipleystevep
'Kin 'ell, rayspeeds never cease to amaze me with their service.
Feckin brilliant IMO
I love a happy ending 8-)
Monty
coaster wrote:I love a happy ending 8-)
Barr 1000 miles running the bugger in again :twisted:
Lamaddict
Yes it's a pain running it in again. I've up jetted it to keep it cooler, it's four stroking a bit but I can get it to smoother revs.
HxPaul
Tut,tut.I got my hands slapped for suggesting that you had to do 1000 miles to run in an iron barrel.
http://scooterotica.org/forum/viewtopic ... r+ally+kit
