Gasket Help
Hughieboy
Main scooter: Lambretta Li S2 GT186
Boreham wrote:Having Known HB for years and all my engines come from him, he tends to use wellseal on on the head/cylnder joining surfaces (he has on every one of mine!)
Thanks for the info! :D
Knowledge
The piston is likely to be a Suzuki TS 185 piston, but probably a copy made by Mitaka. Don't worry, Mitaka pistons are very good, as are the rings.
Martin
Hughieboy
Knowledge wrote:The piston is likely to be a Suzuki TS 185 piston, but probably a copy made by Mitaka. Don't worry, Mitaka pistons are very good, as are the rings.
Cheers, I found out that's exactly what it is..... Cleaned it all up, matched the inlet and exhaust ports, fitted a bigger carb and TSR EVO pipe and it's woken it right up! It's like a completely different scooter. Well pleased :)
