Vespa PX Cutdown
Blakey43
Main scooter: T5 172
What do people do about the frame number when the back end is cut down? Is it worth cutting square around it and tacking it on the frame somewhere else?
lambro
Blakey43 wrote:What do people do about the frame number when the back end is cut down? Is it worth cutting square around it and tacking it on the frame somewhere else?
If you cut it down, I would.
If you are buying one with a small bit of stamped metal not attached as the identity, be careful.
Shaun.
    Users browsing this forum: Google [Bot] and 9 guests
