Backfire on start up
thackers
Hi, I'm looking for a bit of wisdom on a problem I've just started to have. When starting up from cold only I get a backfire crack sound the bike then runs normally. I use the choke to start then let it off once the engine is running as I always have. Does anyone have an answer to this. Thanks
Architecten
Main scooter: Allwyn Pushpak GP125 (RT200)
Electrical. LT coil starting to fail...?
Timbo
Exhaust leak?
LI225Canada
Main scooter: Serveta LI150 Special
The only time I have had a backfire is when Iv had a needle that was too lean, so Im thinking maybe the needle is getting stuck at startup till it warms up??
thackers
Thanks for help, Exhaust seems ok, the ignition is a Varitronic so I'm hoping it's not that. I'll check the needle.
LI225Canada
Also inspect that all the gaskets, seals, rubbers, nuts, bolts, clamps and screws on the carb and intake are good and tight.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 28 guests
