5 Plate Clutch Replacement.
Chris in Margate
I am changing my gearbox soon and was going to change the corks in my 5 Plate Clutch that have been in use for about 5 years but can't seem to find anybody supplying cork plates on their own.
Nothing wrong but whilst I'm in there.....
Question: Are the corks from a 4 plate set up the same thickness as those from a 5 Plate set up as I have a couple of new sets I take on rallys just in case?
Anybody changed theirs ?
hendy
Could be the same as 4 plate or different. Sorry!
Do you have a deep sprocket or not?
If you really don't know, take them out and measure.
Mb sell a set of 6 corks at 2.6mm each and one has angled tangs. They also sell 5 x 3.5mn corks but i don't know about tangs as I've never used them.
Chris in Margate
Standard sprocket. Yep I know; gotta measure when they're out. Just pre-planning.
hendy
If you've got a standard sprocket you must have thinner corks.
So you could use the mb ones. Only £24 for 6 and the angled tangs are nice.
Chris in Margate
Got the thinner steels but couldn't remember if the corks were thinner.
Cheers
storkfoot
As Surflex have been making clutch plates since Adam was a lad and as I have never had any issues with them, I use Surflex green plates in both my 5 plates with rock oil lite gear oil.
Chris in Margate
What thickness and where from?
My sureflex corks measure 13mm for 5 the 4 steels measure 4.6mm top plate is 2.5 mm
storkfoot
Andy Francis:
http://www.ekmpowershop12.com/ekmps/sho ... t-89-p.asp
I use MB Springs. I have not tried the ones that come with the kits. They are not cork so don't use ST90 oil.
