Fork tube length PART 2
chippy
I have an LI series 3 frame which has been cut to take gp leshields. Does anyone know how long the fork tube on the frame should be. I know the difference in length between the gp and LI but don't know if it has been cut right in the first place so I can return it back. Ta
Grumpy225
chippy
I was after the length of the fork tube on the frame if I could find it
wrecklessrobbie
Main scooter: li150
My 1960 series 2 eibar fork tube measures 40 cm exactly.
Robbie
philcasino1973
Main scooter: lambretta gp200
s3 li125 chrome ring model 410mm from top to bearing ring [that is 18mm thick]
phil
chippy
Thanks for that, not chrome ring but no difference in frame I believe
Grumpy225
chippy wrote:Thanks for that, not chrome ring but no difference in frame I believe
My bad, I saw that after I posted it.
chippy
philcasino1973 wrote:s3 li125 chrome ring model 410mm from top to bearing ring [that is 18mm thick]
phil
Is the 410mm the frame tube length. Not including the lower frame cone and upper steering cone. Ta
philcasino1973
its 400mm between lower bearing cup and underside of chrome ring
does the tube go thro to top of chrome ring tho?
phil
chippy
philcasino1973 wrote:its 400mm between lower bearing cup and underside of chrome ring
phil
Mine is not chrome ring. Don't think the frame is any different between the two, it's made up with different size headset bottom. So the 400mm should be the frame dimension hopefully :D
    Users browsing this forum: Semrush [Bot] and 8 guests
