Handlebar Diameter
Boreham
Main scooter: GP225
Could anyone advise the ID of the GP clutch and throttle bar ends, i wanted to order some bar end weights/extensions but the headset is at the sprayshop
Cheers
1 inch. Motorbike bars are generally 22mm so most bike bar ends don't fit well.
warts
Main scooter: honda
I think quite a few Harleys and metric cruisers use 1" bars.
Off road/ADV bikes with alloy bars too?
I welded small discs on my bars drilled and tapped to 6mm and used some cheap aluminium bar ends cost under 3 quid from china , they had rubber bungs onthe end that when you tighten up expand inside hollow motorcycle bars I didnt use those bits ill try and upload some pics
Sent from my C5303 using Tapatalk
Boreham
Main scooter: GP225
Cheers Shocky, a good alternative and theres loads of option options available
Donnie
You are aware that you'll have to cut the throttle and gear rods, shorten them and do some fabrication if you want to fit the internal fitting ones?
Donnie.
