Vespa PX 221 help
smiffy1968
Main scooter: Nevermind Mk1 T5
1.3mm at the moment. It'll probably hang up in the shed for now. The spacer.
Norrie Bodge
Nik221 wrote:And what's your squish band? Today I put my phbh 28 carb on and I have to say what a bloody difference!! I can't explain the difference!! :)
Squish is at 1,5mm m8
Nik221
Main scooter: Vespa PX221...
Thanks, my squish is very big then I need to sort that out.
smiffy1968
What is your squish Nik?
Nik221
I used a 2mm thick solder wire and it didn't touch it so it is more than 2 and that is probably bad.
Nik221
I am in need for some jetting help with my phbh 28. What shall I start from?
smiffy1968
Have a look on here Nik. Carb set ups for Vespa and Lambreta. Good info.
Ginch
Main scooter: Vespa 150 Super
Nik221
Today I went for a ride and my mate was in his car going behind me and he said that we were going 135 km/h and when I took the plug off it was a bit on the white side. Main jet is 115 idle55 x40 needle bottom notch don't know the atomizer is though.
smiffy1968
Hi Nik, good speed and good news[youtube] :D . I've upjetted mine to 135 main, still clean through rev range and fast! Going higher on main. You think you have main jet on your Delly right now?
