Taking a while for revs to drop down to idle...
a.j
After motorway riding, drop the throttle off for any relevant reason, traffic jam, coming off at a junction & the revs don't drop to tickover as they normally should when I slow down. When I'm at a standstill they finally get to tickover nicely, just takes a few seconds.
Any ideas?
LI150
Main scooter: Series 2 LI150
Are you running through air box? Spit back in the bellows.
bristolmod
airleak?
Scootering since 1968.
a.j
bristolmod wrote:airleak?
I'm running an open mouth 28mm delly & thats what I think it could be.
storkfoot
What you describe is a classic symptom of either an air leak or lean jetting. Be careful as, unless you sort it out, you could be heading for a seizure
Starwave
Hello
Does sound like too much air.
I had those symptoms for a while and sorted it by changing the slide (on a 28mm PHBH) for one with a smaller cut-out that I had kicking about.
Might be worth fiddling with your carb after checking for obvious air leaks but before checking for subtle air leaks.
cheers
A leak test kit from Darrell Taylor is a cheaper option than a new piston and re-bore, not to mention the possibility that a seizure can easily throw you down the road.
nelson pk
air leak/ fuel starvation/ incorrect jetting
B-Race Tuning
Main scooter: Lambro, GP.
air leak or worn carb slide or loose exhaust stub?
DigDug
storkfoot wrote:What you describe is a classic symptom of either an air leak or lean jetting. Be careful as, unless you sort it out, you could be heading for a seizure
Holed piston more like....
Did you have to do that?
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
