I want to keep exhaust looking bare metal
simonwwfc
Guys my new handmade exhaust from frank Sanderson has arrived I'd like to leave it looking bare metal as looks so much better I don't want to get it powder coated but don't want it rusting is there anything I can spray or paint onto it thanks
You can get clear powder coat or I think some of the more exotic coating also offer clear, try Camcoat.
ipman
paint it with kurust then clean it with wd40 every time you lock her up and it will last bare metal for as long as you want
nothing else works long term
onthelam
Main scooter: not yet
Clear VHT exhaust paint is available. If you only ride sporadically then the WD-40 route works for me. But do it before you wash the bike?
I do like the bare metal idea though.
simonwwfc
Many thanks
cartmel808
I've used VHT clear satin on one of mine with good results & it seems to be holding up well enough...
The trouble with high temp clear coat for exhausts etc is trying to keep it on and keeping it glossy. The gloss agent in the paint turns matt and peels off. The VHT paint group do a satin clear coat that stays on very well at high temp (over a 1000'c). If you follow the instructions it stays on a very long time. I've seen this stuf used in the F1 industry with great effect. And its available in a can for about a tenner too.
http://www.frost.co.uk/automotive-paint ... rosol.html
simonwwfc
Thanks
