Vespa cdi failure ?
Soulstylist
My scooter is miss-firing intermittently ..
I have rewired any loose connections as needed and checked & cleaned carb,
changed plug, suppresser cap & ht-lead,
I have narrowed it down to two possibilities in line ignition or cdi unit..
when the cdi is on its way out does it start running erratically ?
ie ..as if it's not firing consistently with almost like a lack of power mid way through with the revs cutting in and out ?
ps it's a ducati cdi that's fitted (4 pin type)
cheers for any help
The Kids Are Screaming For That James Brown Style.......
In my personal experience, CDI's tend to just die but LT coils can and do give erratic symptoms. Get hold of a test meter and check the resistance to earth values on the LT coil (green) and Pickup (red). I THINK the Vespa readings are similar to Lambretta ones so you need to see around 430 ohms or better on the LT Coil and 95-115 on the pickup.
Soulstylist
thanks for that
Daggs
Soulstylist wrote:My scooter is miss-firing intermittently ..
cheers for any help
A CDi on one of my lambrettas did exactly that. (and it's a quick and easy change to try, before the LT coil)
Soulstylist
cheers for any help
Cheers guys tried and replaced cdi..defo not that, I am now going to try the LT coil ,,,,
    Users browsing this forum: No registered users and 64 guests
