timing lights
Architecten
Main scooter: Allwyn Pushpak GP125 (RT200)
Sorry, I don't think I worded my original comment very well. I've spotted one on ebay and the seller says it's from clearing his parent's house and not sure if it works or not. It's mains supply so I asked the question did the lamp come on when plugged in. He responded that it didn't but that he thought it had to be connected to the HT lead for it to function which makes sense as other wise it would just be a torch!!! Is this right or do you think it just needs a new bulb!!!
I looked at the Draper but like may others they are battery powered. Mains supply is better for me tinkering in the shed!
No issues with the BGM one that I use.
http://www.lambrettaspares.com/spares/s ... m0443.html
Having said that I've nothing else to compare it against.
firekdp
Architecten wrote: He responded that it didn't but that he thought it had to be connected to the HT lead for it to function which makes sense as other wise it would just be a torch!!! Is this right or do you think it just needs a new bulb!!!
That's correct it will not flash until it receives a pulse from the HT circuit, either by an inductive clamp or in-line connection.
firekdp
corrado wrote:No issues with the BGM one that I use.
http://www.lambrettaspares.com/spares/s ... m0443.html.
BGM? Is that one of these £11 chinese ones?? :D http://m.aliexpress.com/item/1735547155 ... sitedetail
dave411
Main scooter: Li 125
Oh my,I allways thought a timing light was a timing light,battery,12v,and MAINS????
    Users browsing this forum: Amazon [Bot] and 5 guests
