Jettex 22mm float movement
watto66
Hello
I'm having problems ( don't want to throw it away yet ) jetex 22 mm on a 185 lammy apart running crap and flooding I'm wondering how much movement should the float have ? On inspection it seems really tight and stiff should this be the case .mit is a apparent reworked carb , bike keeps running boggy or flooding loads of petrol in the rubber hose . Any thoughts
Many thanks
bristolmod
the float should move freely- sounds like yours is sticking and causing flooding.
Try easing the pivot area.
Chris
Scootering since 1968.
watto66
Thanks mate how do I ease it ? Grind a bit of the pin , drill it out many thanks
Chris in Margate
Run a small drill bit through it by hand. When it's done blow through the other end of the petrol pipe and lift the float and you should feel it close.
Quite a normal problem.
